Re: 240 utility
Posted by K.B. on June 16, 2002 at 21:53:28 from (209.163.14.203):
In Reply to: 240 utility posted by Scott on June 16, 2002 at 19:53:15:
If possible, see if you can have the block repaired.
C-123 engines out of a Super A, 100, 130, 140, Super C, 200, 230 should all be pretty close. The block should be almost identical, although there were a few small variations. I belive the main differences on the 240 were drive belt set-up and a different water pump.
I think a C-135 out of a 340 would fit as well, but wait until someone else reads this and confirms it before you go out and buy a C-135.
Post A Followup
: Re: Re: 240 utility
