Re: 1951 H
Posted by The Red on June 17, 2002 at 12:36:52 from (206.246.187.2):
In Reply to: 1951 H posted by Troy Pestrak on June 17, 2002 at 12:11:02:
Troy after the H is warmed up, set the throttle at full speed and lean the high speed mixture screw until the RPM starts to drop off. Then open the screw back up 1/2 turn. Mixture wise that should get you in the ballpark.
Retard your timing about 10 degrees and see if that helps the starting situation. Might be too far advanced.
Post A Followup
: Re: Re: 1951 H
