Re: New Carb problems
Posted by dan on June 17, 2002 at 16:02:25 from (68.83.34.66):
In Reply to: New Carb problems posted by Bob on June 16, 2002 at 18:42:52:
them old farmalls love to flood if everything isnt just right. too much choke, not enough, float not just right. there are so many reasons its a wonder I love working on these things. First make sure your timing is right. you can play with the carb all night long and it wont mean a thing if the timing is off. then check the idle speed and set it correctly. then with it at low idle adjust the mixture screw till it runs the best. I know that sounds easy but I have been doing it so long I don't know how to explain what I did anymore. Most of the C tractors are around 1/2 to 2 turns out but not all. remember Distributer and timing first then the carb. If you need any help or specs you can Email.
Post A Followup
: Re: Re: New Carb problems
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
