Re: Re: Freewheelin 460
Posted by K.B. on June 17, 2002 at 19:19:16 from (209.163.14.201):
In Reply to: Re: Freewheelin 460 posted by K.B. on June 17, 2002 at 18:42:44:
Here's how the throttle set-up is on my 240 (should be similar to your 460)- Remove the nut, remove the lever, next comes the fricton disk, then remove the plate that bolts to the dashboard, under there will be the spring, and under the spring is a retainer, held in place by what looks like a roll pin. I suppose the retainer could have also fallen out of place, but you'll see what's going on once you get it apart.
Post A Followup
: Re: Re: Re: Freewheelin 460
