Re: Problem with H after rebuild!
Posted by Theman on June 18, 2002 at 05:15:32 from (12.19.86.5):
In Reply to: Problem with H after rebuild! posted by TBR on June 17, 2002 at 18:21:15:
From what you describe the carb is OK. You are getting response from the adjustment screws which is good. Set the idle so you don't see any black smoke. The improperly burned fuel will soot up the spark plugs and cause fouling. Next go to the distributor or magneto and set the timing back a few degrees. It sounds like your valves aren't closing and sealing well and moving the timing back gives them a little more time to close. It also wouldn't hurt to put an ounce or two of Marvel Mystery Oil in the gasoline to help lubricate the valve stems. I had the same problem on my H and this fixed it.
Post A Followup
: Re: Re: Problem with H after rebuild!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
