Re: Re: 460 Turning Radius
Posted by Hugh MacKay on June 18, 2002 at 17:49:33 from (209.226.106.48):
In Reply to: Re: 460 Turning Radius posted by Andy in Ga. on June 17, 2002 at 20:41:26:
We are talking about wide front ends here, and you sir apperently have never had anything to do with a 656 either. In my years farming I had the following wide front end tractors 300, 504, 560D, 656D and 1066. Of those 560 was the worst on manuverability and 656 was the best on manuvering. 656 would make 90 degree turns on mower conditioner without use of brakes and without missing any hay. You can't even do that with a 560, even standing on right brake.
Post A Followup
: Re: Re: Re: 460 Turning Radius
