Re: Re: Re: different bolt patterns for hyd. pump for 300 utility H motor
Posted by Steven@nd on June 19, 2002 at 05:48:37 from (12.15.56.158):
In Reply to: Re: Re: different bolt patterns for hyd. pump for 300 utility H motor posted by mark on June 18, 2002 at 20:11:37:
For your H you will probably need to get the gear that goes with the live pump to make it work. Also I don't know if the gears line up properly with the old cover even if you file the holes out.
As for the M & W pump it should fit with the old cover. I thought that was the benefit of the M&W pump.
Steven
Post A Followup
: Re: Re: Re: Re: different bolt patterns for hyd. pump for 300 utility H motor
