Re: 300 U Hydrolics
Posted by joe on June 19, 2002 at 09:55:46 from (66.43.207.226):
In Reply to: 300 U Hydrolics posted by Dale Kite on June 18, 2002 at 18:36:49:
I would suspect the control valve, since the pump is the same. Or, like fred said, a problem with the lines. Air will usually bleed itself out on those systems it seems like. I bet you have a worn out valve on that thing.
Post A Followup
: Re: Re: 300 U Hydrolics
