Re: tachometer/hourmeter for 300 RC
Posted by Dr. Evil on June 19, 2002 at 10:54:00 from (12.4.181.2):
In Reply to: tachometer/hourmeter for 300 RC posted by jmyt_47 on June 19, 2002 at 09:34:43:
If You don't have the right distributor drive gear housing on Your engine You'll need that also to run Your tach. I put a tach on My Super H 35 years ago....same one Your looking for.... Check salvage yards. It has to have the drive cable outlet coming out on the lower back side at an angle. A little plastic gear has to turn the tach drive cable off the distributor drive pinion.
Post A Followup
: Re: Re: tachometer/hourmeter for 300 RC
