Re: 300 U hyd. pump
Posted by K.B. on June 19, 2002 at 19:05:11 from (209.163.14.211):
In Reply to: 300 U hyd. pump posted by Dale Kite on June 19, 2002 at 17:55:22:
Did it blow the shaft seal and start leaking hyd. fluid into the crankcase? It's not hard to fix, and your Case-IH dealership can get you parts.
Post A Followup
: Re: Re: 300 U hyd. pump
