Re: Super A Water Temp Guage
Posted by SAm in NS on June 20, 2002 at 10:47:37 from (24.138.19.199):
In Reply to: Super A Water Temp Guage posted by Brad Harper on June 20, 2002 at 06:44:05:
The Super A's were never offered in diesel, but they were offered in kerosene/distillate that did have temp. gauges. The cooling system is a thermosyphon which doesn't use a water pump so no thermostat is required. The factory water gauges were mounted in the lower rad. connection so by the time they started showing much heat you were in real trouble. Good luck. SAm in NS
Post A Followup
: Re: Re: Super A Water Temp Guage
