Re: Value of 460
Posted by Tyler on June 20, 2002 at 17:16:09 from (12.64.234.172):
In Reply to: Value of 460 posted by Andrew on June 20, 2002 at 14:01:03:
I paid 1100 for a 460D here in Texas. Paid a little much for it I think but was the first tractor I have bought. Here is what I got.
1 it ran but had alot of blow by (ring and sleeves $400 $500)
2 ta didn't work (cluth and rollers $100)
3 didn't shift into 5th (4th 5th gear $125)
4 some missing tin (white tin by motor& battery
tin) the rest was there and straight ($100-$150)
5 ring and pinion shot( $325)
6 seat cushion gone ($250)
7 temp gauge bad ($65)
8 head work which included new valves, pressure
check, and milled it flat. ($600)
9 crank grind ($100)
10 bearing and gasket set ($200 $300 i think)
11 paint (ppg $400 $500)
12 had good tires on rear and fair on front
There were many other odd and ends that I needed and total cost is over 4000. It was worth it to me because it is something I enjoy doing(most of the time anyway). I always wanted a diesel and I can now go pulling with my dad and brothers. You have to decide what you what it for to make money and sell it or restoring it for fun or farming. Don't think you could make any money as you can see by all my costs. Anyway I don't think I would pay more than $800-$900 but I have only bought one tractor. It also depends where you live.
my 2 cents
Tyler
Post A Followup
: Re: Re: Value of 460
