Re: Hydraulic Valve/Pump Rebuilders???
Posted by K.B. on June 20, 2002 at 20:35:10 from (209.163.14.223):
In Reply to: Hydraulic Valve/Pump Rebuilders??? posted by Bob Kirk on June 20, 2002 at 18:09:56:
Where are the valves leaking from? If they're leaking from in between each other, you just need to replace the 19 or so o-rings. If they leak from the ends, just replace the o-rings under the covers. This system is not hard to work on at all. Your local Case-IH dealership can get you all the parts you need.
Post A Followup
: Re: Re: Hydraulic Valve/Pump Rebuilders???
