Re: 460 steering problems
Posted by Ted on June 22, 2002 at 05:55:31 from (12.216.50.95):
In Reply to: 460 steering problems posted by Curt K on June 21, 2002 at 20:35:00:
I had a similar problem with mine. On the hydraulic valve sitting in front of you (as you sit on the tractor) the one to the right has a one inch long control with some roll pins in it. It points back toward you as you sit on the tractor. On mine one of the roll pins came out and the valve control was turned slightly. This apparently controls the fluid running to the power steering as well as other things. When I turned mine and put the pin back in it corrected my problem.
Try adjusting that valve and check the roll pins.
I think adjusting these valves has something to do with one way or two way, but I am by no means an expert. Thats just what helped my power steering.
Post A Followup
: Re: Re: 460 steering problems
