Re: Water In Oil Pan....Quick Check info Needed!
Posted by Roy on June 22, 2002 at 19:22:35 from (64.12.107.159):
In Reply to: Water In Oil Pan....Quick Check info Needed! posted by Scott L. Swanson on June 19, 2002 at 11:29:33:
I had the same problem with my H that had been sitting unused for several years. I believe that rainwater came in through a poorly fitted exhaust pipe and a cracked manifold,and then down through the head.I tore mine down and the head gasket looked fine and the head wasn't cracked,so I'm guessing that it came in this way.
Post A Followup
: Re: Re: Water In Oil Pan....Quick Check info Needed!
