Re: Timimg mag on C
Posted by gene b on June 23, 2002 at 03:39:56 from (63.25.167.83):
In Reply to: Timimg mag on C posted by Dave on June 22, 2002 at 22:09:27:
there is a mark on the flywheel says tdc and you are in time or else it wouldnt run there is no way to advance or retard the spark as it will fire in tdc when cranking then when it runs goes to 34deg adv you cannot change it if you were to put a dist on the tractor they can be advanced or retarded by rotating the dist
Post A Followup
: Re: Re: Timimg mag on C
