Re: Re: 460 steering problems
Posted by Curt K on June 23, 2002 at 20:35:08 from (209.206.209.152):
In Reply to: Re: 460 steering problems posted by Dillard on June 23, 2002 at 17:45:34:
There is no dipstick on these tractors. What you have is a check plug and a fill cover. Basically the only way you can check the oil is by adding it untill it runs out of the check plug hole. The check plug is located on the left side of the transmission housing near where the hydralic pump is located. And the fill cover is just to the right of the shift lever on the platform just by your feet when sitting on the tractor. Remove the 3 bolts to remove the cover.
Post A Followup
: Re: Re: Re: 460 steering problems
