Re: Re: More H mag problems
Posted by KBBob on June 24, 2002 at 05:41:33 from (205.188.200.37):
In Reply to: Re: More H mag problems posted by Zonie on June 23, 2002 at 21:57:27:
the shaft that the rotor fits on has markings on the end, R and L. Your mag for the H is right hand rotation. Find the space between the 2 teeth of the gear that lines up with the R. They should mesh up with the tooth on the drive gear that has a bevel on it. Hope this helps, good luck
Post A Followup
: Re: Re: Re: More H mag problems
