Re: F-12 or F14?
Posted by jal-SD on June 24, 2002 at 06:21:07 from (64.68.166.199):
In Reply to: F-12 or F14? posted by Ken on June 22, 2002 at 20:40:17:
Ken, F14 is right, but lots of F-12's had an after market kit installed on them to increase the seat height and the steering shaft angle. The kit was available from I-H to make them more comfortable to drive. You could easily have one of these. (My #1 son has 2 of them-his running F-12 has a single front & his parts has dual front wheels.) The only true way to check is by the serial #. Not only is it on the fuel tank support, it is also stamped on the block near the fuel pump. If the block hasn't been replaced, it should be there. If the block was replaced by an I-H dealer, the mechanic was supposed to re-stamp it w/letter suffix, but I've never seen one that was. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: F-12 or F14?
