Re: Re: Re: Bang-Clank PTO
Posted by Gene on June 24, 2002 at 08:26:52 from (65.56.220.82):
In Reply to: Re: Re: Bang-Clank PTO posted by BTD on June 24, 2002 at 08:01:50:
BTD: Can you reduce the load so the driveshaft is under less load while turning?? Second point is to have solid support for shaft so as to reduce floping action. Reducing load while turning may help a lot because the angle causes the shaft to have lots of side force. Adding load makes flopping side2side worse. You don't want to be anywhere near that shaft if it explodes. Could be big danger\injury if that shaft fails.. Careful there!!.. Good luck. G.
Post A Followup
: Re: Re: Re: Re: Bang-Clank PTO
