Re: LiftAll Belly Pump with Broken Pipe Threads
Posted by The Red on June 24, 2002 at 08:28:27 from (206.246.187.2):
In Reply to: LiftAll Belly Pump with Broken Pipe Threads posted by Scott L. Swanson on June 24, 2002 at 07:25:42:
Scott is the pipe broken off at the edge of the manifold on the liftall, or is it broken off in the clutch housing hole where it protrudes out? If it is broken off at the manifold, I would drop the liftall. You might have to find a used manifold and swap out. BTW the manifold is the bolt on assembly that all 3 pipes screw into.
Post A Followup
: Re: Re: LiftAll Belly Pump with Broken Pipe Threads
