Re: Farmal A Coil
Posted by Bob M on June 24, 2002 at 08:50:26 from (165.170.128.66):
In Reply to: Farmal A Coil posted by Todd Davis on June 24, 2002 at 04:19:06:
Todd - If your tractor is still 6 volts, a resistor is not needed. Weak spark could be caused by burned points, a bad condensor or high resistance in the primary wiring.
If the tractor's been converted to 12 volts you need a resistor wired in the series with the coil primary. Mount the resistor wherever handy, but not near the gas tank or anything sensitive to heat (the resistor gets hot in operation). Use a Chrysler style resistor - NAPA part #ICR13 or similar
Post A Followup
: Re: Re: Farmal A Coil
