Darn carb problem in I-544 gas
Posted by Grampsold544 on June 24, 2002 at 09:09:57 from (64.105.216.218):
I have a I-544 gas engin and it starts and runs fine for about 15 minutes then stalls. The only way it will restart is if I spray starting fluid into the carb. Then it will fire right up and idle. When I put it in gear it runs for about 4 feet and stalls out. Then this process needs repeated.
My question is what is wronge with my Carb? Not enough gas when the engin warms up is my guess. Before I drop $300 in a new carb, what adjustments can I make to try to correct this problem. I have already had the carb appart and everthing looks fine. P.S. My floats are not sticking (I have already had someone look at that). I have a Zentith carb with a blead screw instead of a solnoid shut off.
One more piece of info, the fuel pump has been removed and converted to a gravity feed. I can see why it might stall under this situation, but why does it refuse to restart?
Post A Followup
: Re: Darn carb problem in I-544 gas
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
