Re: Pulled the head...everything looks good..Now what?
Posted by Gene on June 24, 2002 at 12:23:23 from (64.156.66.205):
In Reply to: Pulled the head...everything looks good..Now what? posted by Scott L. Swanson on June 24, 2002 at 09:15:20:
Scott: Great time to put some very light weight oil on those piston rings an turn a few turns with a hand crank. I've made a simple plate with a chunk of innertube to snap on inplace of the radiator cap to which I have a hand operated air pump. I can pump up the radiator pressure several pounds.,That would show up the leak. You may be lucky. G.
Post A Followup
: Re: Re: Pulled the head...everything looks good..Now what?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
