Re: Pulled the head...everything looks good..Now what?
Posted by Mr. J on June 24, 2002 at 13:56:54 from (204.184.253.248):
In Reply to: Pulled the head...everything looks good..Now what? posted by Scott L. Swanson on June 24, 2002 at 09:15:20:
Turn the motor over 180 degrees and make sure your sleeves are not cracked at the bottom or top side. Also, might want to re-lap your valves if they have any carbon buildup on them. You can get a valve-lapper at about any parts store, and a valve spring compressor. Take each valve out and re-lap, then put them back in the same hole... Just a suggestion, wouldn't take you an hour and it might keep your tractor from missin when you fire it up. Sometimes the carbon can come loose and stick between a valve and it's seat... That cylinder will loose compression then.
Good luck, tell us how it comes out.
Jared Jeffries
Post A Followup
: Re: Re: Pulled the head...everything looks good..Now what?
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
