Re: LiftAll Belly Pump with Broken Pipe Threads
Posted by LanceM on June 24, 2002 at 14:42:51 from (216.241.129.49):
In Reply to: LiftAll Belly Pump with Broken Pipe Threads posted by Scott L. Swanson on June 24, 2002 at 07:25:42:
Something I have used with success is a hacksaw blade. Grind it down so that it will fit inside the pipe and use it to saw down to the threads, not thru them. Do this several times around the pipe and then use a punch to collapse the pipe into itself. It is slow going but if you are careful it works well, wrap tape around the blade to give yourself something to hang on to.
Post A Followup
: Re: Re: LiftAll Belly Pump with Broken Pipe Threads
