Re: Re: farmall h front tire removal?
Posted by joe on June 24, 2002 at 15:57:29 from (66.43.207.226):
In Reply to: Re: farmall h front tire removal? posted by jal-SD on June 24, 2002 at 15:26:13:
Yep, that's the same thing I do, I use two 2-by's, and that gets it up plenty high. Then you can just do your thing on that side and switch. But otherwise, put the jack under your clutch housing or somewhere in that general area, and block in the same locality, if you have to remove the entire front end.
Post A Followup
: Re: Re: Re: farmall h front tire removal?
