Re: Cub - Replacement of steering shaft bearing?
Posted by George Willer on June 24, 2002 at 16:51:22 from (64.254.134.171):
In Reply to: Cub - Replacement of steering shaft bearing? posted by Ben on June 23, 2002 at 20:18:50:
Ben,
I see you've waited a while without an answer, so here's my $.02. The worm is not intended to be removed, but the bearing is easily replaced from the other end. Don't forget to clean up the area where the seal goes and replace the seal too. It is the most important seal on the tractor. It has to keep water out of the gear box which will quickly destroy it.
George Willer
Post A Followup
: Re: Re: Cub - Replacement of steering shaft bearing?
