Re: Confusion about pushing snow with a blade
Posted by BIG JOHN on June 24, 2002 at 18:44:02 from (205.188.209.78):
In Reply to: Confusion about pushing snow with a blade posted by Grampsold544 on June 24, 2002 at 05:26:32:
Pushing snow is much easier than pulling snow. Just as someone said thought pushing snow with a rear blade will give you a stiff neck. If you pull it be sure to angle your blade so that the snow will escape and not just build up to the point of bringing you to a stop. Pushing snow with a front mounted blade or loader bucked is best. Have fun with your tractor
Post A Followup
: Re: Re: Confusion about pushing snow with a blade
