Re: Compression on a C
Posted by Gene on June 25, 2002 at 08:51:10 from (65.56.61.64):
In Reply to: Compression on a C posted by Pat on June 25, 2002 at 07:24:22:
Pat: Only 25lbs on #2 is Not too good. Depending on type of pistons used, compression can range from about 100 to 135 give or take. The high altitude or fire crater pistons test higher. An older distilate setup would be lowest. You have other problems such as heavy oil comsumption too?? Has it been running? Good luck. G.
Post A Followup
: Re: Re: Compression on a C
