Re: Re: 3 point for a C
Posted by Steve Mason on June 26, 2002 at 06:11:28 from (207.177.31.118):
In Reply to: Re: 3 point for a C posted by Geoff on June 25, 2002 at 16:17:59:
I think it has a 2 point - not sure. It has a 1" rod coming from the touch control unit on the left side that goes back to a pivoting arm on the rear of the tractor. The pivoting arm goes across the back of the tractor and has a connecting point on each side. Currently there is an old homemade scraper blade on the tractor that is raised and lowered with this pivot arm.
I assume this is a 2 point hitch.
Post A Followup
: Re: Re: Re: 3 point for a C
