Re: overbore sleeves for a c-113
Posted by gene b on June 26, 2002 at 16:52:27 from (67.251.189.121):
In Reply to: overbore sleeves for a c-113 posted by David on June 26, 2002 at 16:06:38:
depending on your block you will have to machine some off the sleeve where the rubber ring goes mike your old sleeves first then we can go from there you will need the dimensions also of the top where it seals in the block you can go 1/8 over without and chamges this will give you 123cu when done if you go with the hi-dome fire crater type hp should be around 23 or better you also can increase the rpm to 1800
Post A Followup
: Re: Re: overbore sleeves for a c-113
