Re: Rusted rim
Posted by BIG JOHN on June 26, 2002 at 19:44:47 from (64.12.102.32):
In Reply to: Rusted rim posted by TerryC on June 26, 2002 at 19:04:26:
This is a common problem. What you have is most probably a mixture of calcium chloride and water in your rear tires. It was put there for weight. The calcium chloride is to keep the water from freezing. If you want to replace the water for the added extra weight there are several options for antifreeze that will not cause rust.
The rims can be sectioned to replace the rusted out portions and the valve stem hole drilled at a different location.
Post A Followup
: Re: Re: Rusted rim
