Re: How to detect an electrical leak?
Posted by REM Mo. on June 26, 2002 at 20:21:39 from (207.177.61.8):
In Reply to: How to detect an electrical leak? posted by Andy in Ohio on June 26, 2002 at 19:24:46:
Shut off the tractor and disconect one of the bat cables at the bat. Connect a test light between that cable end and the bat post. If you have a current draw on the system it will light the test light. Start disconnecting things one at a time until you disconnect something that makes the test light go out. You have found what is causing the current drain on the bat.
Post A Followup
: Re: Re: How to detect an electrical leak?
