Farmall Tractors Discussion Board
Re: Farmall M w/ hand clutch
Posted by Ron on August 15, 1999 at 14:56:08 from (153.35.215.126):
In Reply to: Farmall M w/ hand clutch posted by dan on August 15, 1999 at 13:34:10:
Dan,
I have a hand clutch on my Super H that sounds the same as yours. It does give you live power but with mine I have found that if I use it very much at all it begins to slip. I then have to adjust it but if I use it any it will slip again before long. It just isn't big enough.
Ron
Post a Followup
: Re: Re: Farmall M w/ hand clutch
