Re: I-544 Power Steering question, bad vibrations.
Posted by K.B. on June 28, 2002 at 13:12:00 from (209.163.14.177):
In Reply to: I-544 Power Steering question, bad vibrations. posted by Grampsold544 on June 28, 2002 at 05:12:38:
Not quite sure if what you are caling hydrostat power steering is the same power steering system found in most of these tractors 544-656-666-686, or somthing different, but that noise could be caused by air in the system, or mabey a plugged hydraulic filter. Change the filter, and work the remote hydraulic valve levers back and forth to get air out of the hyd. system.
Post A Followup
: Re: Re: I-544 Power Steering question, bad vibrations.
