Re: Re: 340 leaking
Posted by Putter on June 28, 2002 at 16:07:19 from (63.169.76.207):
In Reply to: Re: 340 leaking posted by Eric G. Mann on June 28, 2002 at 07:25:14:
Hi Eric Where do I check the fluid level. I don't have a manual. What weight of oil goes in steering box? Mine must be doing same as your's. She has a shimmy when I drive it, must be tearing up a seal or bearing, probably both. Thanks for your post.
PUTTER
Post A Followup
: Re: Re: Re: 340 leaking
