Farmall Tractors Discussion Board
Re: F-20 axle seals
Posted by Farmall Gray on August 15, 1999 at 18:46:42 from (152.163.201.84):
In Reply to: F-20 axle seals posted by RAW in IA on August 13, 1999 at 18:29:37:
I am in the process of doing these on my F-20.
I got original felt seals from Rice Eq 20 N Sheridan rd, Clarion, Pa. 16214 Ph 814-226-9200
fax 814-227-9200. When you get the seals for the brake drums make sure you order TWO per side.
I got mine before I tore it apart and only had enough for one side. The seals for behind the bearing that is behind the brake drum require 3
per side. I didn't replace these because all they do is keep the differential oil from going into the final drive housing-they won't leak to the outside. The wheel seals are only one per side.
Pay attention when you take these off which way
the cast iron ring that holds them go. The seal goes away from the wheel. If you have a parts book or service manual they both have a cross-section drawing of how it goes together.
Post a Followup
: Re: Re: F-20 axle seals
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
