Farmall Tractors Discussion Board
Re: Re: What type of undercoat paint to use
Posted by Farmall Gray on August 15, 1999 at 19:02:48 from (152.163.201.79):
In Reply to: Re: What type of undercoat paint to use posted by Lyle on August 12, 1999 at 18:56:36:
I have always had trouble using a primer of similar color to the paint. I use a contrasting color so that I can more easily see what spots I missed. And it is easy to miss some spots on a tractor. I guess some could argue that if you did miss some spots it would not be as noticable with a similar color primer. If you are priming the whole tractor it doesn't matter what color primer you use, but if you are only priming spots use
similar colored primer so that is easier to cover.
Post a Followup
: Re: Re: Re: What type of undercoat paint to use
