Re: source for simple hydraulic parts?
Posted by Diesel Don on June 29, 2002 at 06:11:06 from (206.40.118.252):
In Reply to: source for simple hydraulic parts? posted by Joe in Michigan on June 29, 2002 at 05:16:22:
Northern Hydraulics has a good selection of valves if you can't come up with something used.If you have a four way open center valve you can use it as a three way by blocking one outlet port.You need a relief on the pump to do this because when the loader is lowered,the pressure side of the valve will be dead headed.
Post A Followup
: Re: Re: source for simple hydraulic parts?
