Farmall Tractors Discussion Board
Re: A Electrical Short
Posted by big fred on August 15, 1999 at 22:07:08 from (199.238.169.88):
In Reply to: A Electrical Short posted by Mark Scheuer on August 14, 1999 at 21:41:17:
It's probably a good idea to replace your wiring at this point. Once the insulation starts cracking, the wire inside starts to corrode, destroying the wire. Also, if you get an arc thru a crack, the insulation can carbonize, setting up current paths to ground which get worse with time. When you install the new wiring, make sure you get all connections CLEAN and tight.
Post a Followup
: Re: Re: A Electrical Short
