Re: Re: Farmall A Brakes
Posted by Keith on June 30, 2002 at 02:39:27 from (66.84.172.149):
In Reply to: Re: Farmall A Brakes posted by big fred on June 29, 2002 at 20:49:07:
Just did the brakes in my 41 A and as was said the final drives are heavy. I paid $28 for the set of brakes at the local IH dealer. But you will also need two sets of seals because they will be shot when you remove the shafts. You will also have to match a male splined shaft to a female splined shaft and thats the tricky part of the whole thing. The pin that holds the bands to the final drive is two sided..... meaning the pin goes through the band support and into the final drive casting but also goes into the rear end casting. Hope that makes sense??
---(---)--- > pin
cast band cast
And if you bend the pin you will not line up to the opposing part. ( trust me... I did it)
Took my brother and I two hours to change them and had two sore backs after we were done.
Good Luck Keith
Post A Followup
: Re: Re: Re: Farmall A Brakes
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
