Re: Farmall A Brakes
Posted by gene b on June 30, 2002 at 07:25:24 from (63.25.167.99):
In Reply to: Farmall A Brakes posted by John Martin on June 29, 2002 at 20:18:02:
while your at it replace all the seals inner and outer probably are leaking grease maybe you better fill the trans and the final drives first use it for a while then you will know if the seals are good you can buy lining and reline them your self lining will cost about 20 compared to 40 or more for each one the hole set of seals will run about 50 any parts store can get them
Post A Followup
: Re: Re: Farmall A Brakes
