Re: Super C with draining battery
Posted by Bob M on July 01, 2002 at 04:51:32 from (165.170.128.66):
In Reply to: Super C with draining battery posted by Farmer Bob on June 30, 2002 at 22:59:40:
FB - I agree with the Red - most likely your new regulator is bad.
To verify, disconnect the battery ground cable. Disconnect and tape off the wire that goes to the regulator BAT terminal. Then take a resistance reading between the battery negative terminal and a good ground with the ign switch off. If you now get high resistance reading (megohms or infinite), the regulator is the problem.
...Bob M
Post A Followup
: Re: Re: Super C with draining battery
