Re: Re: Re: 460 loader hydralic question
Posted by dick on July 01, 2002 at 07:44:13 from (63.211.244.154):
In Reply to: Re: Re: 460 loader hydralic question posted by Dachshund on June 30, 2002 at 19:11:25:
Is there a cross check valve in the system to keep the bucket leaking down? If so, that might be where your problem is. A quick test for such a check valve: if you have to turn the tractor on to lower the bucket (when it's working normally), you have one; if it lowers without the engine running, you almost certainly don't.
These cross check valves sometimes get crudded up, or otherwise out of sorts.
For what it's worth...
Post A Followup
: Re: Re: Re: Re: 460 loader hydralic question
