Re: Farmall Regular Carburetor
Posted by Ken Williams on July 02, 2002 at 09:37:01 from (63.121.188.117):
In Reply to: Farmall Regular Carburetor posted by Jeff on June 30, 2002 at 19:31:36:
Hi Jeff, I'll try and answer your questions.
1. The big centet knob, on top of the carburator, is the load adjustment. It is the notched knob, with a wire keeper. The small screw is for idle adj.
2. I'm not sure of this, but probably not. You should be able to get one for a Regular or F-20.
3. Most gaskets are available, and I'll leave some info, at the end.
4. 110-115 ft. lbs.
5. Yes, removing these "hand holes", will allow you to inspect the crankcase.
6. This would be an aftermarket item.
7. Yes, you can get them on this site, and through other venders. Companies, that offer Regular parts are, Rice Equipment Co.
E. Main St. Box 267
Clarion, PA 16214
814-226-9200
Kinsinger Service
R.D.1
Meyersdale, PA 15552
Webers Tractor Works
www.webertractorworks.com
There probably other fine companies also, that I have ommitted. I hope this helps.
Happy Tractoring, Ken
Post A Followup
: Re: Re: Farmall Regular Carburetor
