Re: Farmall H Final Drive Removal from Tractor Question
Posted by Ace Schrunk on July 02, 2002 at 10:10:48 from (209.180.99.177):
In Reply to: Farmall H Final Drive Removal from Tractor Question posted by Scott L. Swanson on July 02, 2002 at 09:00:31:
Don't what all you have done, but this is what you have to do. Rmove both axles don,t have to remove housings remove outter cap then you can push axle out remove bull gears ,remove brake drum then remove brake shaft and housing differencial is on inside brake housing bearing
Post A Followup
: Re: Re: Farmall H Final Drive Removal from Tractor Question
