Re: Spliting a super c
Posted by Haas on July 02, 2002 at 13:51:25 from (166.72.245.217):
In Reply to: Spliting a super c posted by Casey on July 01, 2002 at 17:26:30:
I split my C in front of the transmission a few months back to fix transmission oil leaks at seals and gaskets. You need to support the front part really good, make sure it can't go side to side. I found the rear part to be nearly balanced, so a light duty hoist will hold that up. After your get all the stuff off, (steering supports, battery, seat clutch linkage and so on) and have both halves supported, take the 4 bolts out that hold the transmission to the torque tubes. I took mine out one at a time and replaced with longer bolts to help with support. Also good to have those longer bolts to line things up going back together. When you spit, roll back the rear and the main drive shaft will slide out of the clutch. The main drive shaft coupling that has 4 bolts, two connected to the yoke on the drive shaft and two connected to the yoke on the transmission input, will be exposed and you can take the bolts loose and disconnect the shaft. Make sure your clutch remains engaged the entire time you have it split so that the clutch plate will be lined up so you can slide the drive shaft back in. For me, it turned out to be easier than I expected. If you have more questions, let me know.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
