Re: 300 U carb rebuild? Extra parts ?!!
Posted by The Red on July 04, 2002 at 10:52:49 from (12.84.240.165):
In Reply to: 300 U carb rebuild? Extra parts ?!! posted by gerald on July 04, 2002 at 10:42:38:
Gerald that carb. should be similar to the early Ms. There is a spring and ball assembly which ride under the face of that choke shaft located on the carburetor housing. Note the small hole in that choke shaft facing. When the choke is wide open, that ball should rest in that small hole so the choke doesn't close on you unless you activate it. Hope this makes sense.
Post A Followup
: Re: Re: 300 U carb rebuild? Extra parts ?!!
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
