Re: 300 U carb rebuild? Extra parts ?!!
Posted by dick on July 04, 2002 at 13:04:40 from (63.211.247.215):
In Reply to: 300 U carb rebuild? Extra parts ?!! posted by gerald on July 04, 2002 at 10:42:38:
Had a similar experience when I had the carb out of my 300U, and a little extra ball showed up. Now where the heck did that come from????
The Red is right as usual, it goes out on the choke lever. It and the little spring that goes with it give the lever some drag so it stays where you set it.
Post A Followup
: Re: Re: 300 U carb rebuild? Extra parts ?!!
